1979 Clubman 1100. Some light engine mods: cam, rockers, exhaust. Standard ignition. Electric fuel pump + filter.
Hi Experts!
I was powering up a hill the other day when suddenly the engine went 'weird' under load. Revs became irregular; it felt like it wanted to stall. I had to give it a lot of gas to get home. Came back to the car after a week or so and struggled to start it from cold. Again very unsettled idle (perhaps misfire?) and stalled. Now cannot get it to start at all. Cranks over fine on the starter motor but will not fire.
Things I have already checked:
- points - clean and correct gap
- dizzy cap and rotor changed. No improvement.
- tappet clearances - all correct
- fuel getting to carb - yes. Fuel is pumping. Can smell petrol in cylinders.
- spark present at HT lead - yes - tested for spark from all leads against head.
- cleaned all connections around solenoid. All wiring looks good. No obvious damage.
- carb partially inspected - fuel in float chamber looks OK. Piston, needle etc all looks normal.
- timing seems correct ballpark - (marks on the flywheel are in the right place relative to the dizzy and cylinder 1 at TDC.)
Things I suspect:
- spark plug failed? (Have ordered new ones to rule this out, awaiting arrival)
- something has slipped in the timing somehow? Chain jumped a tooth?
- spark is too weak somehow?
Engine is normally in good working order having only been rebuilt a few years ago, although it was running quite hot over the summer. Something has failed due to hot running?
Any suggestions much appreciated!
