Cosmic 5X10
15 replies to this topic
#1 gaspen
gaspen
  • 980 posts
Posted 28 November 2022 - 12:20 PM
Hello
I've put my hands on a set of Cosmic wheels but they need some care and I need some answer
1) With which nuts were these fitted to the wheel hub originaly ?
2) Were they painted silver/black by the factory ?
3) The steel insert is available as a spare parts somewhere ?
     Unfortunately some of these fallen out from the wheel
4) May I use different wheel nuts for fitting without the steel inserts ?
Attached File  20221127_134907.jpg   45.51K   2 downloads
Attached File  20221127_134350.jpg   40.67K   3 downloads
#2 nicklouse
  • 18,697 posts
Posted 28 November 2022 - 12:28 PM
You will need to have a look at the inside of the insert. It will be fairly obvious to see if it is a radius or a round seat.
unfortunately round seat ones are NLA ( or I have just not found any) changing to the tapered seat ones will require a full set and a full set of nuts.
#3 humph
humph
    How bad can it Be?
  • 1,108 posts
Posted 28 November 2022 - 02:14 PM
Can't really help with all of your answers, not without taking the wheels of my car and I'm afraid that's not possible at the moment.  I can say they were black and silver from the factory I believe.
The centre caps are available here https://www.johnbrow...uct/cosmic-CCCO
As are replica wheels to give you an idea what they should look like, albeit diamond cut which I don't think the originals would have been.
https://www.johnbrow...-4x1016-6010COS
#4 gaspen
gaspen
  • 980 posts
Posted 28 November 2022 - 02:31 PM
 Possible solution is to find some nice nuts and ask a machine shop to produce the inserts for it
#5 nicklouse
  • 18,697 posts
Posted 28 November 2022 - 02:34 PM
Or just buy the tapered ones. See https://www.theminif...date-it/page-56
#6 gaspen
gaspen
  • 980 posts
Posted 28 November 2022 - 03:05 PM
Well, now I see what you talking about  :D
Would you make me happy with a part number for those nuts ?
#7 nicklouse
  • 18,697 posts
Posted 28 November 2022 - 05:25 PM
https://www.raceways...eel_inserts.htm
they do nuts as well. Have a read and do some measuring.
#8 gaspen
gaspen
  • 980 posts
Posted 28 November 2022 - 05:40 PM
Cheers ! I just found it a minute ago
#9 gaspen
gaspen
  • 980 posts
Posted 30 November 2022 - 07:25 AM
One more question : those insert must fit tightly into the wheels ?
#10 nicklouse
  • 18,697 posts
Posted 30 November 2022 - 09:00 AM
They are a friction fit not an interference fit but should not be loose. Measure the diameter of your old ones and post the info up. I have my old ones I can measure for reference.
#11 whistler
whistler
  • 1,818 posts
Posted 30 November 2022 - 11:53 AM
They were black and aluminium from factory.
This is from about 1973.
#12 gaspen
gaspen
  • 980 posts
Posted 30 November 2022 - 04:01 PM
Here we go
Attached File  20221127_134350.jpg   46.77K   1 downloads
Attached File  20221127_134400.jpg   49.96K   0 downloads
#13 nicklouse
  • 18,697 posts
Posted 30 November 2022 - 06:24 PM
That’s the same as I took out but some person had run them on a 4x100 car so they were a bit worn. I still have them Somewhere.
the hole in the center is bigger and the taper different. So new nuts and possibly studs if you have unthreaded stud showing.
#14 gaspen
gaspen
  • 980 posts
Posted 30 November 2022 - 07:22 PM
Thanks a lot
I have CN2 nuts from MiniSpares to my ATS wheels. These are 60-degree tapered. I guess they will be fine to the new tapered inserts that you showed me
Attached File  20220924_170911.jpg   101.54K   4 downloads
#15 nicklouse
  • 18,697 posts
Posted 30 November 2022 - 08:03 PM
Mmmmmm in theory yes but I went for these https://www.raceways...Zinc_finish.htm
they have a bigger diameter taper but the same socket size.
