Engine Paint Block And Gearbox
8 replies to this topic
#1 Colakurt
Colakurt
  • 57 posts
Posted 04 December 2022 - 03:53 PM
I have taken my engine apart and want to paint it. I would like to avoid spray paint as much as possible. I have been looking at Hammerite and can see on this forum that a lot of people have used it with succes on the block and head. But what about the gearbox of aluminium? My first thought wold be either Hammerite with metal primer or maybe their new Ultimate version. I just can't figure out if the water based Ultimate is resistant to heat, oil and gasoline as the origin version is?
For the engine block I would like a bright red and not sure if Hammerite smooth red will give me that or if I will be better of with brake caliber paint?
#2 PoolGuy
PoolGuy
  • 854 posts
Posted 04 December 2022 - 04:20 PM
Hammerite smooth will be fine, if it comes off with the heat from your head/block, the paint will be the least of your worries. It’ll be fine on the box too.
#3 Colakurt
Colakurt
  • 57 posts
Posted 04 December 2022 - 06:10 PM
For the aluminum parts I'm more concerned with oil and gasoline if I was to use the Ultimate version that is water based but also can stick to anything other than cobber.
I'm sure the normal stuff will work for the iron parts.
#4 Colakurt
Colakurt
  • 57 posts
Posted 06 December 2022 - 09:26 AM
I got a reply from Hammerite. They don't recommend the Ultimate version for the gearbox application. So I have to use their metal primer or some other solution.
#5 PoolGuy
PoolGuy
  • 854 posts
Posted 06 December 2022 - 10:32 AM
Like Hammerite smooth?
#6 nev100
nev100
  • Just Joined
  • 143 posts
Posted 06 December 2022 - 07:55 PM
Get in contact with Frost.
They do an engine block paint....and know their stuff.
#7 MiNiKiN
MiNiKiN
  • 200 posts
Posted 07 December 2022 - 10:23 AM
I would generally prime the aluminium parts with etch primer (an epoxy primer with acidious portion) that slightly etches the surface and hence will stick like the proverbial on a shovel.
Then apply the top coat (I use standard enamel paint)
Edited by MiNiKiN, 07 December 2022 - 10:30 AM.
#8 nicklouse
  • 18,657 posts
Posted 07 December 2022 - 03:45 PM
I don’t paint the gearbox but do paint the rest.
Block and head 2 pack the other bits with rattle can acrylic.
#9 Steve220
Steve220
  • 5,062 posts
  • Local Club: BMC
Posted 07 December 2022 - 06:03 PM
I've just redone my block and head after doing it with halfords own (terrible) paint. The block was de-coked first as it was in for machining, which got all the old paint and grease off, and left the metal ready. Used Simoniz black gloss engine enamel - one can did the engine, head and alternator mount with 4 coats.
