I have hi-lo's with rubber cones fitted on my '93 Mayfair, running 10x6" wheels. The Front is fine with a nice even gap between tyre/arch on both sides, but the back is uneven, with the passenger having a bigger gap than the drivers side. Only about 10mm but it looks odd when comparing.
I have tried to lower the ride height on that side by adjusting the hi-lo, but it gets to the point where the whole arm starts to turn including the trumpet and cone and becomes loose.
Could this be worn/compressed cones, more on one side than the other, or could there be something else at play? Surely, if adjusted to the point just before the whole piece starts to move, the car should be much lower?
Advice Welcomed.
