Hi ,
when I got the 1989 River Mini it was down a little on on3 side.
I changed all the Cones and Shocks and fitted Hi-Lo all around.
The front is now ok I was able to adjust the Hi-Low
However the rear drivers side is a different story which is down by 1cm.
I screwed out the hi-lo what I thought was enough…put the wheel on and drove around the block
measured it again and it’s the same.
Did the process again screwed out some more…..still the same.
The hi-low must be near the end of the thread but still the same.
am I missing something…..
The subframe is new also camber brackets are fitted.
I can understand how the front raises the ride height but I can’t quite understand how the rear lateral hi-low adjustment raises or lowers the car
i would appreciate some help here. Thank you
