Hello. Im quite new to working on minis.
I have an SPi which has had some tinkering with by the previous owner. I was having trouble with fueling, stuttering, bucking, not running right, so Im working my way through the common bits, vaccuum pipes, coolant sensors, inlet manifld pipes etc
Not sure what kind of exhaust I have, or how to tell, except that I have twin, rear exit pipes. I dont know how to tell if the header is standard or not.
I have removed the Lambda sensor - there are no markings on it whatsoever, and I have bought a new genuine Bosch one, the part number is 0 258 003 193 / MHK10004.
The old one I took out seems to be 1/3 smaller than the new Bosch one!
So do you think the one I took out was incorrect, or is the new one potentially the wrong one - given that my header may not be "stock"?
tia
Edited by orac69, 18 December 2022 - 10:41 AM.
