Twin Carbs Repair
13 replies to this topic
#1 miniGTS
miniGTS
  • 307 posts
Posted 25 December 2022 - 07:57 PM
I've been digging through my crates of parts and found twin carb bodies AUC870 and AUC871. The AUC870 (I have 2) bodies seems to be missing a part of it, see the attached picture, can that be repaired somehow?
Edited by miniGTS, 25 December 2022 - 07:59 PM.
#2 miniGTS
miniGTS
  • 307 posts
Posted 25 December 2022 - 08:03 PM
I also have a carb body AUC82 as in the pic attached, is there a reason I can't use that one instead as it's the same side as the AUC870
#3 nicklouse
  • 18,998 posts
Posted 25 December 2022 - 08:16 PM
On a twin setup you don’t use that anyway.
#4 miniGTS
miniGTS
  • 307 posts
Posted 25 December 2022 - 08:26 PM
Ohhhh, cool thanks. So that 870 body should be good to go for a rebuild.
#5 nicklouse
  • 18,998 posts
Posted 25 December 2022 - 08:28 PM
Well let’s put it this way. All the twin setups I have seen hold the cable outer and the inner connects to the operating rods not the carb bodies.
#6 imack
imack
  • 2,372 posts
Posted 25 December 2022 - 11:26 PM
They're used for the choke cable. You only need to have one on one carb body.
#7 miniGTS
miniGTS
  • 307 posts
Posted 26 December 2022 - 08:56 AM
Will it possibly work if I cut and adapt this to work for the throttle and choke cables? The other side of the carb doesn't have a choke cable top either.
#8 imack
imack
  • 2,372 posts
Posted 26 December 2022 - 10:11 AM
Not for twin carb setup.
Choke cable goes to one carb, throttle cable attaches to linkage between the two carbs. This is HS4, but HS2 is the same.
#9 miniGTS
miniGTS
  • 307 posts
Posted 26 December 2022 - 10:28 AM
Thank you for the pic. I'll have to make a plan then for the choke cable. The hole is there on one carb body but no cable stopper in the hole. Should be fairly easy to fit one.
#10 miniGTS
miniGTS
  • 307 posts
Posted 26 December 2022 - 12:24 PM
Sorted thanks. I think I have the choke stopper fitted in the correct side based on pics of the twin hs2 carbs that I've seen.
Thanks for pointing me in the right direction
#11 miniGTS
miniGTS
  • 307 posts
Posted 26 December 2022 - 12:48 PM
Is the float bowl on the hs4 and hs2 the same?
#12 imack
imack
  • 2,372 posts
Posted 26 December 2022 - 04:17 PM
They're very similar but I don't know if they're exactly the same/interchangeable.
#13 imack
imack
  • 2,372 posts
Duplicate
Edited by imack, 26 December 2022 - 04:29 PM.
#14 imack
imack
  • 2,372 posts
Posted 26 December 2022 - 04:23 PM
Duplicate
