Hi all,
I've had my 1994 mini 35 for nearly 4 years now and shes been a dream to drive, but now i've started noticing a big drop in oil pressure during hot idle specifically, and an almost stalling sounding knock that's definitely coming from the bottom end... fearing the worst!
Its a 1275 on basic parts, nothing done to the internals, just a hif44, lcb, rc40, stub stack filter from MED and had it tuned by AC dodd this year.
I do look after the mini, full service every six months and it really doesn't see that many miles as it's not my daily driver. I always check the oil and water levels before taking it for a drive too.
I fitted the oil pressure gauge a while back and never used to see it get quite as low as it does now after just an hour or two of driving.
Now it can be less than 10 when i get home and go to park it up, which is when i hear some bottom end knock sounds....
This year i plan to take the engine out and pull it apart. I live in cornwall and would love to have the confidence in it to drive further to bigger shows ect.
I'm also thinking if it's all coming apart then perhaps i should get some internals upgraded too.
Found a 12G940 with bigger valves, bronze guides, ported and polished with double springs which i can't miss, so also wondering what best mods may be good to go with this. Originally i was thinking rebore +20 to a 1293 then maybe sw5 cam and 1.5 rockers, but not sure if this is all necessary to achieve a basic increase of power?
Also worth noting my current block is all A+ series.
Basically i have two questions; what kind of mods would best go with this head in order to achieve a nice increase of power?
And also is it better to rebuild/rebore my A+ short or to find a 1275 short engine that's already been rebored/rebuilt and then just assemble a completely new engine to just swap over?
Money is a factor but not as big as build quality and reliability.
Many thanks in advance, I think it's obvious i'm a bit green but keen hahah so any advice would be appreciated
