Thermostat Onto Cylinder Head
6 replies to this topic
#1 barneyman
barneyman
  • Just Joined
  • 52 posts
Posted 08 January 2023 - 02:46 PM
Hi,
As part of our latest project to replace the radiator on our 1275 1992 Mayfair, we have removed the thermostat housing and have been presented with the following gunk including some metal fragments, see photos attached.
We have not had any recent issues when running the engine so hopefully this is normal to see and maybe we should simply clean it out as best as possible.
However, your thoughts and guidance would always be appreciated.
Many thanks in advance!
#2 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 08 January 2023 - 04:10 PM
Pretty normal for a 30 year old engine. Probably run with weak anti-freeze (or none!)
#3 mbolt998
mbolt998
  • 407 posts
Posted 08 January 2023 - 04:12 PM
Mine looked at least as bad. I tried running a garden hose into it as best I could, and then ran it up to temp with regular water which I then drained out before refilling with antifreeze. I make no guarantees about whether it will actually be OK :)
#4 Ethel
  • 26,073 posts
Posted 08 January 2023 - 04:18 PM
That's an observation, not advice, I take it  :P
Probably worth taking the opportunity to give it a good flush. Also unwind the studs, provided they don't want to put up a fight, so you can clean up the gasket faces & 'stat rebate.
#5 croc7
croc7
  • 817 posts
Posted 09 January 2023 - 08:32 AM
This is from the ‘for what it’s worth’ department;
If I were you, reinstall the old radiator-you don’t want contaminates running through the new rad-and flush the cooling system with a brand name cleaner. This is the method that I use;
-water and cleaner into radiator
-open heater valve
-run engine to temp + 10 minutes to circulate cleaner
-allow to cool
-drain rad
-remove t’stat & test it
-install t’stat housing/gasket without t’stat
-fill radiator with water
-rotate upper rad hose 90 degrees ccw at t’stat housing & install a 3’ section of garden hose. This becomes the H2O outlet & run it into a container (have plenty available).
-have a source of fresh water (lots) available to pour into radiator. I use a garden hose or jugs of distilled water.
-start engine and run at idle, pouring water into the radiator as necessary until water runs clear from t’stat outlet hose into the containers.
-once your satisfied the system is clean, re-install the t’stat/fresh gasket, connect the hoses and fill with coolant, 1/3 anti freeze to 2/3 water.
Hope this works for you.
Edited by croc7, 09 January 2023 - 08:40 AM.
#6 coopertaz
coopertaz
  • 807 posts
  • Local Club: a-series-magpies
Posted 10 January 2023 - 11:37 AM
looks like normal crud from weak mix, as mentioned above. flush engine, rad and heater matrix out well and use correct mix should be fine
#7 barneyman
barneyman
  • Just Joined
  • 52 posts
Posted 12 January 2023 - 08:43 PM
Thanks all, appreciated the responses, always helpful
