Test fitting the 998 engine into my 1978 Saloon and the Header and Intake manifold do not fit. Could use some work arounds if there is one. I received the car with 10 boxes of parts. It came with the original car and manifold and also a pair of HS 2 carbs and header. When I test fit the header and HS 2 manifold, the intake manifold will not attach to the head as the left header is in the way. Have not idea of the part number of the header (also brand) and the intake manifold is a 12G489 which I can find no reference material on it. So a bit blind here.
