What Clutch Type To Mg Metro 1988 Engine?
10 replies to this topic
#1 Zaki
Zaki
  • 20 posts
Posted 17 January 2023 - 08:24 AM
Hello!
I bought a new engine for my project- 1275 from MG Metro (1988)- and I'd like to ask you guys about a clutch that would suit me best.
This is going to be a bit faster road car. It has Pre-Verto clutch mounted and I was thinking about changing it to Verto as I've heard
that is easier to setup/balance etc. (I know that I'll have to buy all additional parts like the new bracket, slave cylinder, etc.)
I am not gonna race it or raise car's power to more than ~80-85bhp.
What do you think guys?
#2 MiniMadRacer
MiniMadRacer
  • 889 posts
Posted 17 January 2023 - 09:09 AM
Persoanlly I am a Pre Verto Clutch man every time
#3 whistler
whistler
  • 1,801 posts
Posted 17 January 2023 - 12:45 PM
Stick to the pre Verto clutch.
#4 Zaki
Zaki
  • 20 posts
Posted 17 January 2023 - 03:00 PM
Isn't Pre Verto's setup/balancing more difficult? Does the pedal feel like in the modern cars? I'm confused as I've heard that it is harder and for a comfy ride I should pick Verto.
Edited by Zaki, 17 January 2023 - 03:00 PM.
#5 nicklouse
  • 18,618 posts
Posted 17 January 2023 - 03:39 PM
Nope it is simple. Get it balance and it is done for life. And the tolerances were better.
don’t try comparing any mini clutch to a modern car.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,751 posts
Posted 17 January 2023 - 04:51 PM
Verto is the clutch if you want the lighter feel and smoother operation.
Things have moved on a bit and the verto flywheel is ideal for fast road applications.
Why people want to use a clutch that put more load on the crank thrust washers is beyond me,
https://youtu.be/hTmWuW2yYDc
https://youtu.be/uW05K_FglkE
Ac
Edited by ACDodd, 17 January 2023 - 04:54 PM.
#7 Zaki
Zaki
  • 20 posts
Posted 18 January 2023 - 09:17 AM
@ACDodd I've seen your videos before and are awesome. I am thinking about switching to Verto but ready sets with a flywheel are a bit expensive.
I would have to buy all the additional parts like boss, keyways, small clutch arm, different slave cylinder etc.- 650£- that's a lot for just changing a clutch.
This is why I don't negate Pre-Verto solution :mmkay: .
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,751 posts
Posted 18 January 2023 - 09:29 AM
Ok then if you already have the older type of parts then use those. Bear in mind the old type clutch can also benefit from optimising.
https://youtu.be/myx0mnLYv4g
And
https://youtu.be/w3G5Tn6VsxY
Ac
#9 Zaki
Zaki
  • 20 posts
Posted 18 January 2023 - 01:36 PM
And what do you guys think about that kind of kits that are balanced but come with lightened flywheels. Do I need a slightly lightened flywheel in a faster road car? :shy:
https://www.med-engi...-light-st1-1234
#10 stoneface
stoneface
  • 373 posts
Posted 18 January 2023 - 02:01 PM
Sorry for the slight thread hijack, but interested in this too.
I already have a lightened pre-verto clutch/flywheel balanced with crank ready to go.
Crank, pistons and block is all built up without gearbox attached.
Because of the thrust issues I was thinking of going to a verto but 2 things bother me.
Will I notice much difference with the slight weight increase of a lightened verto over a pre-verto.
Does a dynamically balanced assembled kit such as MED supply need balancing with the crank? or can it just be fitted. Reason I ask is my engine is all bolted up and stripping down to get it all balanced again would be a pain and a cost.
Is the force applied to the thrusts much lower on a verto over a pre-verto?
#11 Icey
Icey
  • 1,551 posts
Posted 18 January 2023 - 03:16 PM
I posted in the duplicate of this thread that I use one of those and have done on the last few engines. Not had a problem with them (but did also point out the issues AC Dodd has seen with some of these kinds of kits).
