Locking Choke Cable - Recommendations Please
9 replies to this topic
#1 Mini M
Mini M
  • 19 posts
Posted 17 January 2023 - 05:30 PM
Hi All,
Does anyone have any recommnedations for where to get a choke cable that works. I have a '74 Mini with a Metro engine and has a locking type of choke cable which never stays locked.
Today particularly in the icy weather, it was a right pain to keep the choke out by hand to warm the car up.
I've recently come back into Mini ownership after many years and wondered is there now an electronic solution for the choke?
Thanks,
M
#2 Shooter63
Shooter63
  • 1,092 posts
Posted 17 January 2023 - 09:02 PM
Just use a clothes peg to hold it open, it's been standard equipment for years.
Shooter
#3 Tds76
Tds76
  • 87 posts
Posted 17 January 2023 - 09:29 PM
The cable lock can be repaired though it is a bit fiddly.
 - Remove the cable from the car
 - Slide the spring (black ring) down the housing
 - Take out the worn plastic lock key
 - Make a new key. I made one from a 1/4" bolt: hacksaw down the bolt held in a vice, then rotate and saw off a small piece. Might need a bit of filing to clean up and make fit in the hole in the housing.
 - Replace the spring, then re-fit to car
See https://www.ausmini....=99842#p1057454 for photos
Cheers, Paul
Edited by Tds76, 17 January 2023 - 09:30 PM.
#4 unburntfuelinthemorning
  • 1,991 posts
Posted 17 January 2023 - 10:00 PM
I bought a new cable from Minispares and it works well.
#5 Chris1275gt
Chris1275gt
  • 969 posts
Posted 17 January 2023 - 10:29 PM
Before attaching it to the carburettor lock the knob on and when attaching it to the carburettor twist the cable a little more then tighten the nut. By doing that it means the choke will not jump out of lock due to the twist of the cable as the twist you put on it is wanting to lock it and it doesn’t alter the operation of it except when you release the choke you have to push it in and keep it from locking on.
#6 Steam
Steam
  • 842 posts
  • Local Club: Victorian Mini Club
Posted 18 January 2023 - 01:03 AM
Shooter
This is the answer KISS principle at its best.
#7 burchy35
burchy35
  • 116 posts
Posted 18 January 2023 - 06:13 AM
I think the peg is one of the most useful accessories to have in a mini.
Once it has finished been used to hold the choke open I clip it on the heater controls to stop them from vibrating. Win win.👍
#8 alpder
alpder
  • 449 posts
  • Local Club: MCR
Posted 13 January 2024 - 11:31 AM
This answer should be pinned... it converted my dodgy clothes-peg-needing choke cable into a fully functional locking one, with 2 minutes work.
#9 Steve220
Steve220
  • 5,075 posts
  • Local Club: BMC
Posted 13 January 2024 - 01:01 PM
I took the spring off.
#10 Ethel
  • 26,104 posts
Posted 13 January 2024 - 01:55 PM
A Bowden cable is an option.
That's the solid wire type that can push as well as pull. Set it up with the right curve in the cable path and the friction will hold it without any locking
