Mk1 Boot To Mk3 Retrofit.
12 replies to this topic
#1 Cyclops63
Cyclops63
  • 82 posts
Posted 26 January 2023 - 08:43 AM
Hi all. I fancied a drop-down plate for my mk3 so got an old mk1 boot which I'd read is a straight swap. Checked it for size. Bingo. Then filled/painted it. BUT, when going to fit, I realised I hadn't checked the hinges at the time and they're about 3/4" different. 😭😭
So, looks like I'll have to drill new holes in the boot or rear panel. Rear panel may be easier. Any thoughts please?
#2 imack
imack
  • 2,110 posts
Posted 26 January 2023 - 09:17 AM
Should be a straight swap.
Went from mk3 to mk1 boot on my 72 mk3 with no issues.
Edited by imack, 26 January 2023 - 09:18 AM.
#3 mab01uk
mab01uk
  • 12,421 posts
Posted 26 January 2023 - 09:28 AM
As said should be a straight swap unless something has been changed to non-standard on bootlid or your Mini....photos would help.
#4 Cyclops63
Cyclops63
  • 82 posts
Posted 26 January 2023 - 11:09 AM
Thaks guys. will revisit the scene of the crime and try to take pics
#5 stuart bowes
stuart bowes
  • 2,118 posts
Posted 26 January 2023 - 01:53 PM
Also measure the fixing hole centres, probably easier than trying to tell by looking at a picture
I currently have no boot lid fitted so can easily offer comparison if required
#6 Cyclops63
Cyclops63
  • 82 posts
Posted 27 January 2023 - 06:47 PM
DOH! I'm talking out my hat. It's a Mk4!
#7 imack
imack
  • 2,110 posts
Posted 27 January 2023 - 07:49 PM
All boot lids should fit all mk's
#8 Cyclops63
Cyclops63
  • 82 posts
Posted 03 February 2023 - 06:33 PM
So here are the pics. The angles aren't great because I didn't have a helper yo offer up the lid to the rear end but there is clearly a 3/4" discrepancy
Edited by Cyclops63, 03 February 2023 - 07:40 PM.
#9 sonscar
sonscar
  • 3,000 posts
Posted 03 February 2023 - 07:03 PM
The hinges look to be on the wrong sides of the car.Steve..
#10 Cyclops63
Cyclops63
  • 82 posts
Posted 03 February 2023 - 07:42 PM
I may well be a complete idiot. First thing in the morning I'll change them over although I looked for offset on them and didnt see any. But I do only have one eye...
#11 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 February 2023 - 09:11 PM
The hinges are labeled RH and LH if you look at the casting on the back of the hinges.
They do look the wrong way round in the pictures but I'm not sure that swapping them will make enough difference though especially assuming that the hinges are still fitted as they were with the old bootlid?
Having them wrong tends to just cause minor alignment issues and slight binding when opening and closing
Might be worth doing some measuring up
Mark a centre line on the hinge panel and measure out to the hinge mounting holes and report here with them so one of us can compare
do the same with the bootlid too
Ben
#12 Cyclops63
Cyclops63
  • 82 posts
Posted 04 February 2023 - 08:47 AM
Will investigste today and report back
#13 Cyclops63
Cyclops63
  • 82 posts
Posted 05 February 2023 - 10:54 AM
Ah. Mea Culpa. Swapped the hinges over and bingo! At first sight I couldn't see any difference at all between them but clearly marked on the reverse. Many thanks for everyone's help.
Edited by Cyclops63, 05 February 2023 - 10:56 AM.
