Modifying Centre Speedo Warning Lamp Colour
12 replies to this topic
#1 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 28 January 2023 - 09:44 AM
I have the centre binnacle type speedo and modified the wiring so that the left and right orange warning lamps light up with the respective indicators.
nowI was thinking of using the green one at the top as a warning lamp for either the brake fluid level or fuel level. Though I don’t want green for this. Any suggestions on how I might go about changing the green lens to red or orange?
#2 Clip
Clip
  • 185 posts
Posted 31 January 2023 - 10:28 PM
I did stumble across replacement crystal lens somewhere once, but can’t recall from where, but they were available. What are you using for oil pressure warning?
Edited by Clip, 31 January 2023 - 10:36 PM.
#3 KTS
KTS
  • 2,482 posts
Posted 31 January 2023 - 10:52 PM
Here you go
https://embertonimpe...er-series-1-2-3
#4 Clip
Clip
  • 185 posts
Posted 01 February 2023 - 01:03 AM
Got to love this forum  :thumbsup:
#5 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 06 February 2023 - 02:47 AM
I have an oil pressure gauge  :proud:
#6 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 06 February 2023 - 02:48 AM
thanks! It's a little on the pricey side, so I'd have to think about it. but do you know how I'd go about removing the existing lens from my speedo?
#7 nicklouse
  • 18,741 posts
Posted 06 February 2023 - 07:49 AM
Mmm please check your local road use regulations. The colour and action of these telltales are actually regulated.
#8 KTS
KTS
  • 2,482 posts
Posted 08 February 2023 - 01:36 PM
sure.
with the speedo unit on the bench, fold back the tabs securing the chrome rim and remove it from the body.
with the unit face down on the bench undo the two screws either side of the speedo drive (shown above) and lift away the housing
the lamp jewels are held in place by sprung washers - with a pair of thin screwdrivers the washers can be 'walked' off the posts.  this needs to be done carefully to avoid snapping the plastic
#9 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 08 February 2023 - 02:47 PM
to quote Captain Barbarossa, traffic laws in my country are "more like guidelines"  :lol:
#10 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 08 February 2023 - 02:48 PM
thanks @KTS this is good stuff
#11 GraemeC
GraemeC
  • 7,450 posts
Posted 08 February 2023 - 02:53 PM
Easiest is to get an old, broken speedo unit from ebay or the forums and take it apart to liberate the lenses you want.
I put a green lens on either side for the left & right indicators and an orange lens at the top.
#12 Ethel
  • 26,141 posts
Posted 08 February 2023 - 03:41 PM
That's not a bad idea, it wouldn't have to be Mini. I did think of the panel mount warning lights, but you'd be unlikely to get a good match, even if you managed to cut one down with something like a spot weld drill.
Masses of this stuff about:
https://www.ebay.co....CxoCAbcQAvD_BwE
#13 splintercat
splintercat
  • 616 posts
Posted 11 February 2023 - 07:10 AM
agree with GraemeC easier to get an old unit off flea/bbay and utilise it, Altho looking at f/b now they are silly prices, u will be able to pick em up at a show for less than that, or someone on here will have have one.
