Replacement Headlamps
Posted 04 February 2023 - 01:46 PM
I need to replace the headlamps on my 1971 Mini.
It currently has the sealed beam units (as link below)
https://www.minispar...px|Back to shop
If I change to the quadratic halogen headlamp kit below - is it simply a case of removing the unit and disconnecting the wires from the back and then connect the new unit and pop it back in? Or is there other parts/wiring required?
Posted 04 February 2023 - 02:07 PM
Pretty much,
As you can see in your link (says they're out of stock, by the way) you'll likely have a little bit of splicing to do for the sidelights.
There can sometimes be problems with light units being deeper than the headlamp bowls, but you should be ok with regular H4's. Just be aware of it & the risk of shorting if bare metal on the back of the bulb connector can touch a metal bowl.
Posted 04 February 2023 - 03:10 PM
Posted 04 February 2023 - 04:33 PM
Shooter
Posted 04 February 2023 - 09:18 PM
If you can find a pair, the Cibie headlights are definitely the best which use an H4 bulb.
I have a pair of Hella with H4's on one of my cars and with100W main beam H4's they are great, but the wiring has to be upgraded and relayed to use the 100w main beam halogen bulbs.
Another good option is the Autopal units. I used a pair a long time ago and they were fine.
But then, anything is better than the original sealed beam 'electric candles'
Posted 04 February 2023 - 09:47 PM
Posted 04 May 2023 - 09:40 AM
Headlamps now delivered - but I have a little problem.
The back of the news ones are not the same as the old ones. The 3 spades are positioned the same. But my existing electrics/connector have the side light bulb (I presume) connected as part of the connector that plugs into the 3 spades, and the old spades on the old lights are configured to allow the connection and room for the side light bulb to sit over a clear part of the back of the light unit (so it can shine through). Whereas the new Quadoptic lights dont allow for the side light bulb - you cant push the connectors on to the spades as the bulb prevents this - plus there is no clear area for the side laight bulb to shine through. Photos below. Can I make these new lights work with minimal adaptions, or is there a different route I have to take.
Old light unit
Electics/connector
New light unit
Posted 04 May 2023 - 11:58 AM
Posted 13 May 2023 - 06:26 PM
Old light unit
Electics/connector
New light unit
Are you satisfied with the new lights?
