Oil Transfer On Post 1992 Engines?
5 replies to this topic
#1 alpder
alpder
  • 549 posts
  • Local Club: MCR
Posted 09 February 2023 - 05:50 PM
Rebuilding an A+, believed to be SPi. It came to me very bare, in particular missing the oil filter housing and the oil transfer pipe.
Thought I could use one of my random spare oil filter housings, transfer pipe, and banjo. Turns out I can't because the banjo thread is too small for the block. Seems later engines used a flexi pipe?
What's my best way forwards? Without spending a fortune on "race" bits! For example, is there a special-sized banjo-bolt I can get so I can just use my old filter-housing and solid pipe? Or a flexi pipe whose threads will match the block and my old filter housing?
#2 alpder
alpder
  • 549 posts
  • Local Club: MCR
Posted 09 February 2023 - 06:54 PM
OK - found the answer (I think). It'll be one of these braided pipes...
http://www.minispare...ic/MOC1018.aspx
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 09 February 2023 - 06:57 PM
You'd be best to use that flexible type, the standard 92 onwards can push out the unions
#4 nicklouse
  • 18,998 posts
Posted 09 February 2023 - 07:02 PM
The post 92 engines did not use a banjo. As you have found out.
#5 Spider
  • 15,684 posts
Posted 10 February 2023 - 12:01 AM
Originally, they had a steel pipe, that had a tube nut and olive where they screw in to the block, the thread is 11/16" UNF on these. The earlier blocks were 5/8" UNF.
#6 viz139
viz139
  • 721 posts
  • Local Club: Irish Mini Owners Club
Posted 10 February 2023 - 10:44 AM
If you don't have a later oil filter housing and want to use your older one you will need a different pipe
http://www.minispare...ic/MOC1020.aspx
