Engine Main Bearings Oil Holes
5 replies to this topic
#1 cristiano1968
cristiano1968
  • 444 posts
Posted 10 February 2023 - 09:24 AM
Hello
I would like your opinions on the bearing oil holes as they do not line up.
The car
998cc engine has worked top notch for 30 years
I'm doing a rebuild.
Should I leave them ad they are?
Or should I enlarge them
Inevitable got acl bearings
And they don't line up.either
Any opinions thanks
#2 DeadSquare
DeadSquare
  • 3,197 posts
Posted 10 February 2023 - 11:45 AM
Leave them, that is ample orifice for oil to lubricate the crank.
Before cars had oil pumps, the con-rods of my "straight 6 Hudson", had "Dippers", a small spoon on a 'forward facing' tube that splashed into the oil in the sump and guided enough oil to the Big-ends for some to be flung out during rotation.  A little of this alighted on the webs of the Mains and trickled to the edge of the Main bearings.
#3 GraemeC
GraemeC
  • 7,440 posts
Posted 10 February 2023 - 01:37 PM
For a standard, or slightly warm, 998cc they will be absolutely fine.
If it were an all out race/rally monster then it would be worth fettling the block.
#4 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 10 February 2023 - 04:14 PM
It'll be fine. The pressure will fill the bearing nicely. I do hope those are the old bearings and not the new ones.. they look filthy!
#5 Lplus
Lplus
  • 911 posts
Posted 10 February 2023 - 05:32 PM
I'm not sure I'd bother for a cooking 998, though it's always nice to know that every restriction has been removed if possible.  The real question is whether you can remove every single piece of metal dust/shavings/whatever from the oilway after the work.
#6 cristiano1968
cristiano1968
  • 444 posts
Posted 10 February 2023 - 09:27 PM
Yes they are the old bearings.
I'll think I'll leave the holes as they are
It's a standard 998cc
Upgrade pistons +20
I use it to go around town
Not racing
Thanks for all your answers๐Ÿ‘๐Ÿ‘๐Ÿ˜
