Spot Lamps In Grille
1 reply to this topic
#1 Pukka666
Pukka666
    Starting My Mini Up
  • 1 posts
Posted 10 February 2023 - 08:37 PM
Hi there. I'm looking at getting a new grille with spot lamp holes already cut out. Just wondering about the best lamps to use and how to fix these in position. All feedback much appreciated.
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,363 posts
  • Local Club: Amoc
Posted 13 February 2023 - 04:35 AM
Suppose it depends what youmare using the lamps for, fog lamps or driving lamps.
Also depends what your running mpi minis have a front mount radiator and limited space for lamps..
There was (historically) a set available from what if i remember correctly to be wood and picket with the lamps encompassed into the grill.
Also how are you going to wire the lamps you require...
Anything is possible i suppose but couple more things to think about.
