Improving the gas-flow of siamesed inlet ports.
When Austin decided that pairs of cylinder would share an inlet port on their new A series engine, I wonder why they chose an "Up-Down-Down-Up" crankshaft ?
This imposed the 1, 3, 4, 2, firing order which results in the 3-4 port having to cope with two sucks in quick succession, then "resting" while the 2-1 port struggles with two sucks.
If we cut between 2 and 3, and join the crank and cam together again at 180 degrees to make an "Up-Down-Up-Down" crankshaft, we could have a 1, 3, 2, 4 firing order.
This would allow 1-2 port to devote all its gas charge to number ONE cylinder, followed by number THREE cylinder having a good suck through the 3-4 port without having to share the end of its gas charge with FOUR, because TWO would have been filling before FOUR started to suck.
I will have to ask Father Christmas for a bigger soldering iron. !
