Mini Spi 1.3 1992 Running Rich And Stalls On Idle
8 replies to this topic
#1 timvandenboo
timvandenboo
  • 10 posts
Posted 28 February 2023 - 10:09 AM
Hi all,
For a long time, I have been enjoying my mini spi now. But after an engine overhall this winter, it is running horrible. Starting the engine takes around 6-8 turns while in past only 1-2 turns. Then when moment/acceleration is needed, engine dies and wont come up again until 30 sec later. (like the gasoline needs to fape) Also on the highway running 80 steady, randomly engine dies. Feel like over fuelling and I have to wait 30 sec to be able to start the engine again.
So I hope people here can help me sort out the problem.
Specs:
Stage 3 head SPI specs
SPI KENT CAM
Checked so far:
Dual plug ECU swapped for a Cooper S ECU Dual plug
New wiring loom ECU
New vacuum lines of 3mm tube (multiple times)
New vacuum tube to brake pod
Checked fual trap. (swaped)
Swaped injector for spare
New Temp coolant temp sensor
New lambda sensor (gave problem on hessitation so swapped to old one and runs way better)
Swapped stepper motor as old on was corroded.
Removed Cat
Manifold exhaust fully sealed -> no leaks
Extra earth wire
MAP measured with external vacuum meter and displays same values as MemsFCR
When I read the information from the ECU with MemsFCR; (WHen hot)
idle 850
Map 43
Stepper 35
Lambda stuck on 465 (checked with multimeter and jumps up and down low - High etc)
Ignition advance 12-14 (jumps around these values)
So the weird thing is that at random moments the SPI (i think) overfuels and thus dies.
Does anyone has a suggestion?
Thanks in advance.
#2 humph
humph
    How bad can it Be?
  • 1,107 posts
Posted 28 February 2023 - 01:08 PM
See the thread below which is similar.
https://www.theminif...ady-high-840mv/
in this thread I posted.
The error some make is rushing to replace the sensor without checking the wiring to it, one of the larger specialists did exactly this with mine.  On mine the wiring had rubbed through and broken behind the throttle body, I believe that this is quite common. The break meant that the supply to the sensor was intermittent.
The second time I had a similar issue the sensor was damaged by a failed coolant temp sensor.  Again this is mentioned in the threads Matthewsdad posted.
#3 timvandenboo
timvandenboo
  • 10 posts
Posted 28 February 2023 - 01:16 PM
hi Humph, thanks for your quick reply. I already read through that post but I already eliminated the wiring and played with blocking the fuel line to see if the lambda is working.
Also for wiring issues, i changed my full wiring loom for a minispares new one and either before or after the swap, no improvements can be found....
(I had to change the loom either way as the previous owner soldered and changed a lot on it, and due to corrosions it reached it end of life.)
I also swapped the temp sensor with another one I had laying around. No effect.
Same as the ECU, swapped, no effect.
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,369 posts
  • Local Club: Amoc
Posted 28 February 2023 - 02:17 PM
Have you considered changing the fuel pipes over as the new fuel,additives these days eat away at the rubber pipes on minis?
#5 hungdynasty
hungdynasty
  • 174 posts
Posted 28 February 2023 - 02:19 PM
My car is a 98 JDM SPI with ignition coil, I had similar problem as yours and I replaced the crank sensor and problem gone.
#6 genpop
genpop
  • 528 posts
Posted 28 February 2023 - 05:30 PM
What about not too much fuel but too less.Check the fuel supply. Is the pump running? What if you directly supply the pump with current? What about the line pressure?
Normally the pump is 30 years old, a good time to die.
#7 timvandenboo
timvandenboo
  • 10 posts
Posted 02 March 2023 - 11:09 AM
Thanks for all your replys
Crank sensor has been replaced and is new.
Fuel lines have been checked and no blockage to tank.
Maybe indeed the pressure is not sufficient enough. Will double check it this week with a pressure sensor. Thanks for the tips.
#8 pete l
pete l
  • 1,374 posts
Posted 02 March 2023 - 01:59 PM
Would it run rich if the fuel pressure was too low ?
If so, why ?
#9 genpop
genpop
  • 528 posts
Posted 02 March 2023 - 04:37 PM
Fuel will not be sprayed in but drops out of the imjection nozle. Therefore it is not burned completely. But may be  a matter of battery and generator together.Not enough current when idling.Altogether there is not enough information for diagnosis. He only can test one after the other.
