Spi To Carb At Mot Time
Posted 28 February 2023 - 12:34 PM
I'm not a fan of the SPi system and want to change to carb.....any ideas how to get through an MOT? I understand if I fit an older engine it's all good, but how could I convince the tester?
Posted 28 February 2023 - 01:32 PM
Section 8:2 of the MOT testers manual says that vehicles used before 1 September 2002 with a different engine must be tested to the requirements to which is older, the vehicle or the engine.
There must be some work around this conversion to a carb, you need to convince the tester as to the age of the engine, the onus is on the vehicle presenter to prove the age of the engine.
It appears it is up to the tester if he accepts your presentation, but I am sure the more inventive could produce a "ghost" engine number that can be checked back to be an engine that was originally fitted with a carb.
OF COURSE I WOULD NEVER CONDONE SUCH DECEPTION.
Good luck.
Posted 28 February 2023 - 01:37 PM
Posted 28 February 2023 - 01:38 PM
Posted 28 February 2023 - 08:16 PM
There is a document which shows from which point engine number onwards regarding how it has to be tested regarding emissions. Ie CO and also whether the CAT has to be in place.
I will have to dig out the data but it is about on here and online, I just need to dig it out as I needed to be ready for the “conversation” with the tester but none needed as based from engine number.
Edited by E23TFD, 28 February 2023 - 08:18 PM.
Posted 28 February 2023 - 09:07 PM
Minimail supply engine numbers with no fuss
https://www.minimail...sis-vin-plates/
Edited by floormanager, 28 February 2023 - 09:08 PM.
Posted 01 March 2023 - 08:09 PM
Mini Model Code XN
1.3l Auto TBi Engine Code X Serial No 059845 onwards
1.3l Manual TBi Engine Code X Serial No 059822 onwards
1.3l TBi Engine Code Y Serial No 060488 onwards
1.3l MPi Engine Code Z
Posted 02 March 2023 - 04:44 PM
Edited by Hensor, 02 March 2023 - 04:50 PM.
Posted 02 March 2023 - 08:34 PM
