Any Trick To Seating The Inlet Manifold?
9 replies to this topic
#1 madazv8
madazv8
  • 124 posts
Posted 01 March 2023 - 11:45 AM
Hi,
Just put my intake manifold back on and appear to have made some sort of mini-amateur error, as I have now a healthy air leak on one side of the intake manifold to head joint. Everything looked lined up and as it should be,  all torqued up normally.  What do I need to be looking out for when I re-do this?  Thanks in advance.
#2 KTS
KTS
  • 2,441 posts
Posted 01 March 2023 - 12:24 PM
are the flanges on the exhaust and intake manifolds the same thickness ?  thicker exhaust flange will mean the intake is loose
#3 sonscar
sonscar
  • 3,011 posts
Posted 01 March 2023 - 12:35 PM
Have you trapped anything between it and the head?Steve..
#4 madazv8
madazv8
  • 124 posts
Posted 01 March 2023 - 12:47 PM
Exhaust and intake are standard SPI items,  so don't expect thickness to be the issue /  Nothing obvious trapped.  Maybe I didn't line up the tubular insert between them correctly...
#5 madazv8
madazv8
  • 124 posts
Posted 01 March 2023 - 12:55 PM
Item 10 here. Thinking maybe this wasn't seated correctly...
  • Attached File  10.png   215.12K   1 downloads
#6 FlyingScot
FlyingScot
  • 2,664 posts
Posted 01 March 2023 - 05:55 PM
Check you actually have item 10. On many SPi I see they are not present.
FS
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,356 posts
  • Local Club: Amoc
Posted 02 March 2023 - 04:12 AM
I would ask if the faces were all clean when you put it all together..
I think i would, order another exhaust gasket, then carefully take the old one off and examine it see where the issue was and clean all flange faces and spend the time to make sure you are happy with all before progressing..
The leak may not be where you think it is.. could be a crack in the inlet or a leak at any servo take off...
Investigate propa see what you find...
#8 madazv8
madazv8
  • 124 posts
Posted 06 March 2023 - 11:59 AM
Well after strip down,  said ring was not there.  Found it between the head and the exhaust manifold. Also the face of the inlet is pretty messed up.
Thanks folks.
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,356 posts
  • Local Club: Amoc
Posted 06 March 2023 - 07:52 PM
All part of the service....
#10 tmsmini
tmsmini
  • 731 posts
  • Local Club: MOASF
Posted 07 March 2023 - 02:20 AM
You can actually see where the ring was not seated properly at some point and left its mark on the inlet.
