Hey all,
Not sure that is the right wording but wondering your throughs this. I installed a DSN timing over and have the entire cooling system apart. Was wondering about the fans location, in relation to the rad and the shroud around it. My 94 SPi originally had 2, 4mm (Rover) spacers between the pulley and the fan but I bought a single, 11mm alloy spacer from DSN. I know the spacers were original placed there to ensure there was enough clearance between the fan and the timing cover breather that is on the A+ motors BUT does it make sense that you would want the fan to be tucked under as much of the fans shroud as possible? Getting the fan as close to the rad as it can? I would think it would "contain" more of the air and transfer it through the fin.
Anyone have a theory on this one?
