Hello.
my gearbox in my racer is an a-plus box with the s-ratio conversion (DAM3169 and 22G1040 I believe), which means I have 2'nd (22G1094) and 3'rd from a 1977 mini 998. This works great, but my 2'nd gear needs changing now as its worn and I was comparing it to the a-plus single-groove second gear and have a hard time seeing the difference, neither teeth count or diameter or anything like that. I know from reading, amoungst other things moke spiders gear set table, that it has to be the 22G1094 with this laygear and such, but why cant I use the DAM4932 gear in my case?
his table is in here:
https://www.theminif...-which-gearset/
thanks in advance
Martin.
