Gearbox Case Transfer Idler Bearing Removal
10 replies to this topic
#1 ac427
ac427
  • 678 posts
Posted 13 March 2023 - 09:04 PM
When i removed the idler bearing for the transfer gear from my gearbox casing. I didn't use a blowlamp, just the old 2 sockets and a length of studding method.
Is heat definitely required?
Have i knackered my gearbox casing removing the bearing this way?
Edited by ac427, 13 March 2023 - 09:04 PM.
#2 lildeucecoop72
lildeucecoop72
  • 112 posts
  • Local Club: Norsk Mini Cooper Club
Posted 14 March 2023 - 07:35 AM
Regarding your case - probably best to post a pic if you can?
I have not used heat for the idler bearings, only first motion bearing race, but I guess that could work.
A puller is best, home made like the one you describe, or the even better very rare special BL tool made by V.L. churchill in the 60s if you can get your hands on one.
The other method if you have a steady hand, are feeling brave and replacing the bearings anyway (which is reccomended) is to very carefully cut it out with a tool like the dremel, taking care not to cut into the transfer case itsfelf. This is a last resort though. The bearing case is fairly soft and bendable so you can 'help' it out with pliers, small drifts etc.
If you are doing the one on the gear box side, remember to remove the circlip first if there is one..!!
I forgot to do this once using a puller, not seeing the circlip. I forced the bearing through the circlip making a right mess, nearly wrecking my gearbox case in the process.
#3 Spider
  • 14,867 posts
Posted 14 March 2023 - 09:18 AM
A puller is all that's needed for the Idler Gear Bearing in the Gearbox case, I wouldn't advocate using any heat here.
In regards to the Transfer Case, the factory explicitly caution against using heat here;-
#4 lildeucecoop72
lildeucecoop72
  • 112 posts
Posted 14 March 2023 - 02:15 PM
Wow, this is interesting - seems to be a lot og info and videos showing the heating method...(even from proffesional gearbox builders) and that seemed to be the way to do it.
Is this a case of that so many have done it this way, that its become 'accepted/normal' ?
#5 KTS
KTS
  • 2,423 posts
Posted 14 March 2023 - 02:39 PM
i must admit to using a steam wallpaper stripper to heat up the casing to help get it out.
an alternative to a puller is to push it out using hydraulic action - Nicklouse posted that a while back
#6 floormanager
floormanager
  • 691 posts
  • Local Club: Mini Club Sussex
Posted 14 March 2023 - 07:25 PM
You been watching videos on Youtube showing using heat?  I used a stud and socket method.  The video used a hammer and socket.
#7 Spider
  • 14,867 posts
Posted 14 March 2023 - 07:41 PM
It's never been acceptable as far as I am aware and I have had to rectify - or try to - cases that have been distorted from having been heated.
#8 ac427
ac427
  • 678 posts
Posted 14 March 2023 - 08:58 PM
Thanks Spider, I thought this was the case.
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,346 posts
  • Local Club: Amoc
Posted 19 March 2023 - 08:23 PM
Hammer time...
Keep away from the heat there... to many delecate bits in there
#10 Kevybmini
Kevybmini
  • 87 posts
Posted 04 March 2024 - 08:27 AM
But off topic but when you set the idler gear end float - when you do the final assembly would using gasket sealer then effect this tolerance or is gasket sealer not required on the transfer case.
#11 KTS
KTS
  • 2,423 posts
Posted 04 March 2024 - 08:47 AM
assuming normal application, use of gasket sealer shouldn't make any measurable difference
