Hi there,
Is it common or possible to change the wheel studs that come on 7.5'' brake discs? Need to fit spacers and not sure if I'm getting the wheel nuts on enough threads.
Posted 18 March 2023 - 08:07 PM
Hi there,
Posted 18 March 2023 - 08:09 PM
Not that easy as you can’t go that long.
but if you are needing to use spacers you have the wrong wheels. Spacers are nasty.
Posted 18 March 2023 - 08:27 PM
Posted 18 March 2023 - 08:47 PM
Very true, however my wheels are already 6 x 10'' and they sit too far in the arches
Posted 18 March 2023 - 08:54 PM
Posted 18 March 2023 - 08:56 PM
Wrong arches then.
Posted 18 March 2023 - 09:02 PM
I have the classic group 2 arches
Look like this
Posted 18 March 2023 - 10:09 PM
Posted 18 March 2023 - 10:11 PM
Look like this
Perfect.
so let’s see yours.
from what you say they look like that.
Posted 18 March 2023 - 10:44 PM
Purely in answer to the OP question.
Hi CallumAustin11 - as you may see from the above answers - your question revolves around safety critical bits - so take extra care
In Theory
Yes, it is possible to fit longer studs. Threading to at least the stud thickness IIRC - so for 3/8 studs -at least 3/8ths engagement.
If replacing studs on discs (any length) - be aware that some studs have mushroom type ends - and clearance can be an issue - wheels click or stop when spinning - so best addressed early
In Practice ( Note all the warnings above I agree with for a road car - match correct studs and wheel nuts)
On race cars - if you can't get flat backed wheel studs - carefully grind the mushroom but don't over thin it. ( Easier to have some spares already done rather than try and do it in situ.
To ensure engagement and importantly full tightening when more than one type of wheel is being used , i drill through all the wheel nuts and tap the thread all the way through
Another word of warning : the lug nut (wheel nut) taper /fittings can be different for different wheels so for example Contessa Nuts are different to more modern 60 degree tapered fittings
NOTE NOTE NOTE : on a road car with lovely chrome wheel nuts that are closed off on the end - it is hard to know whether the nut has bottomed out before fully tight - thus all the warnings about nut/stud lengths
AFAIK Spacers on a road car are a big NO NO
Posted 18 March 2023 - 10:54 PM
In Theory
And to reiterate. 7.5” discs. You can’t physically fit studs much longer as there is a disc on the way.
but again there is no reason to use spacers if you have the correct wheels and arches.
Posted 18 March 2023 - 11:20 PM
Posted 19 March 2023 - 12:14 AM
Posted 19 March 2023 - 09:18 AM
I'm using a set of 10" Rose Petals from Mini Spares, they came with hub centric spacers and two sets of wheel nuts for use with different length studs. I need to use the spacers on the front to clear the caliper, and also on the rear I am using MiniFin alloy drum, I think its got the built in spacer, but seeing as they supplied 4 spacers, I used them on the rears as well, which does give much better clearance from the shock absorber.
Posted 19 March 2023 - 10:09 AM
Sorry just to correct you they can’t be hub-centric spacers as the drive flange does not have a lip to mount them to. The edge that they would have mounted on is angled so does not locate them. The Metro drive flanges were hub-centric with the four lugs on them which had to be removed to get most of the Mini wheels to fit.
