Brake Pedal, No Clevis Pin?
4 replies to this topic
#1 Rabonitez
Rabonitez
    Starting My Mini Up
  • 2 posts
Posted 27 March 2023 - 08:03 PM
I was looking to replace the plate beneath my brake & clutch master cylinder as it’s rotten and split where the engine steady bar connects. I understand that I need to remove the clevis pins from both the brake and clutch pedals, in order to lift up the cylinders to access the plate. Upon inspection the clutch pedal was as I expected, with a clevis pin and retaining clip, but the brake pedal doesn’t have the same set up. It looks like a flat pin head either side of the pedal, with no retaining clip.
Does anyone know what this is and how it should be removed?
#2 Icey
Icey
  • 1,556 posts
Posted 27 March 2023 - 08:12 PM
That’s normal when you have a servo fitted, the clevis is on the top side.
#3 mab01uk
mab01uk
  • 12,639 posts
Posted 28 March 2023 - 08:35 AM
12 - NAM8539 - Brake pedal R/H when servo fitted from 1988. As said Clevis is up the top of pushrod behind the servo/master cylinder assembly.
Diagram of the later servo pedal (item 12) here:-
http://www.minispare...s.aspx?2~17~141
Edited by mab01uk, 28 March 2023 - 08:38 AM.
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,451 posts
  • Local Club: Amoc
Posted 28 March 2023 - 05:25 PM
Rover made it just that little bit harder to twist the additional elbow in and up through the bulk head...
Gee thanks...
#5 coopertaz
coopertaz
  • 819 posts
  • Local Club: a-series-magpies
Posted 29 March 2023 - 09:03 AM
Gee thanks...
also made it easier than having your head stuck in footwell
