I have a 92 mini Mayfair with the three binnacle clocks can you and if so how do you remove the clear plastic front so I can clean it inside
Three Binnacle Clock Face
Propshaft
, Apr 03 2023 05:21 AM
3 replies to this topic
Posted 03 April 2023 - 05:21 AM
Posted 03 April 2023 - 07:01 AM
you will need the clocks out of the car, they have screws that hold the clocks to the surround, and then from memory the clear plastic either unclips or is held on with more screws.
Posted 03 April 2023 - 07:22 AM
I am fairly sure it just pulls off leaving sprung tabs screwed to the clocks,Steve..
Posted 03 April 2023 - 07:31 AM
Ok the clocks are out I will try and gently pull them off cheers
