Newbie With Headlight Problem
Posted 03 April 2023 - 08:43 AM
Just bought a 1980 Mini 1000 (Photos to follow once I’ve removed some unwanted bling “upgrades” such as Cosmetic extra headlights, bars, chrome internal door fittings & bonnet straps as pretend Italian Job).
However, one of the real headlamp’s full beam wasn’t working & I thought one useful upgrade that was worth doing would be a conversion from sealed beams. I bought the Wipac conversion set and started fitting them. Had to change the sidelight/pilot terminals which I stupidly did before trial fitting. Then found out the sidelights on the Wipacs fouled the inner headlamp aim adjustment ring/bowl so new ones won’t seat properly!
Managed to rewire the terminals with a temporary connector so I could put original back in but has anyone else found this issue. Do I need to get a different fitting instead (eg Quadoptics where sidelight wiring is slimmer as no bulb holder sticking out the back) or have I possibly got a non-standard bowl/ fitting I should replace instead?
Many thanks
Dan.
Posted 03 April 2023 - 09:18 AM
Could be any of those, nothing involved is Mini specific. It shouldn't be too hard to work a solution, perhaps some different sidelight bulbs/holders with wire tails or leds?
Posted 03 April 2023 - 09:52 AM
Here’s a photo of car as originally bought. Extraneous headlamps (not wired in) are now removed. Next step is to drill out rivets holding on the bonnet straps (which again are purely decorative and don’t actually hold down bonnet). The eight holes will need infill caps (small grommets may fit & look ok) or filler/prime/paint. There’s a rust patch on near side Lower A panel which needs attention at some point so may do the two together.
Clutch is a little harsh on take-up so needs adjustment/ investigation.
A couple of other minor jobs to do.
Apart from that it all seems good and ready for driving - day trip to b-roads around the foothills of Pennines planned for this week.
Dan.
Posted 15 April 2023 - 10:36 PM
Found out that clutch release spring is non original & too stiff so causing clutch to engage too harshly. Temporary fix of adding an extension between spring & lever (bit of old key ring) seems to help. New spring on order
Posted 16 April 2023 - 07:59 AM
Posted 16 April 2023 - 08:37 AM
Posted 16 April 2023 - 06:31 PM
Mine was a fair bit shorter than the spec I read somewhere but elsewhere suggests using stronger spring to overcome judder! Will have to see what happens when I fit original spec one! Cheers.
Edited by Crumbly, 16 April 2023 - 06:36 PM.
Posted 16 April 2023 - 06:39 PM
Cheers.
Posted 06 May 2023 - 04:00 PM
Posted 11 May 2023 - 11:18 PM
Edited by Crumbly, 12 May 2023 - 06:35 PM.
