Over a period of several months of irregular use the windscreen wipers became progressively more reluctant to move until they no longer moved at all.
The wiper motor appears to run fine and the rotor turns. I have tested this with the connecting rod from the rotor to the cable disconnected.
https://www.flickr.c...land/es3840kWP9
Can that rotor operate under no load but seize as soon as a load comes on?
I tried pulling the cable through but after about 7cm or so movement it jammed, and proved impossible to push back in. I have been convinced that either the cable was totally gunged up in the area of the two wiper arm boxes or the mechanism in the boxes themselves is seized. If I unscrew the nuts on the wiper spindles is it possible to withdraw the entire edifice sideways out, or must all the gubbins on the bulkhead be removed to get access?
Thoughts and advice from anyone with knowledge of what’s under there would be gratefully received.
