Fuel Pump And/or Max Pressure For 1275 With Hif44?
6 replies to this topic
#1 Rick Anderson
Rick Anderson
  • 29 posts
  • Local Club: MOALA
Posted 03 April 2023 - 09:20 PM
I want to switch from a mechanical fuel pump to an electric fuel pump on my 1275 with an HIF44 carb. I see that there are several brands and options available regarding fuel pressure. What pressure should I be looking for and are there any particular pumps that are recommended? I prefer to not use a regulator if possible.Thanks for your help.
#2 Ethel
  • 25,938 posts
Posted 03 April 2023 - 09:58 PM
Facet solid state pump, doesn't need to do above 3-4 psi. Does need to be mounted below & near the tank.
#3 whistler
whistler
  • 1,793 posts
Posted 04 April 2023 - 08:40 AM
I use an ECCO pump on 2 of my Minis. Located in the rear subframe with a hidden switch in the cab to isolate the pump if necessary.
https://simonbbc.com...r-installation/
Straight replacement for the SU pump.
#4 croc7
croc7
  • 810 posts
Posted 05 April 2023 - 07:25 AM
Mini Spares sell the Hardi electric fuel pump that is very good and reasonably priced. I use one and have had good luck with it.
#5 Rick Anderson
Rick Anderson
  • 29 posts
  • Local Club: MOALA
Posted 06 April 2023 - 12:11 AM
Do you need to use a regulator with it?
#6 croc7
croc7
  • 810 posts
Posted 06 April 2023 - 02:49 AM
Nope. I use it with a HIF44 on a 1360 without issue.
Edited by croc7, 07 April 2023 - 06:12 AM.
#7 coopertaz
coopertaz
  • 795 posts
  • Local Club: a-series-magpies
Posted 11 April 2023 - 10:01 AM
use facet red top on mine. mounted under tank, filter king regulator on front bulkhead
Edited by coopertaz, 11 April 2023 - 10:08 AM.
