Mini Spares Super Fit Arches
1 reply to this topic
#1 The-evil-GT
The-evil-GT
  • 103 posts
Posted 16 April 2023 - 04:04 PM
Hi everyone , I’m looking at fitting some fibreglass arches to my mini , the wheels I’ve got on it are a little too wide so rub at the front, I looked at these arches but wasn’t 100% sure because the description says “ The flares attach by screws to the same body lip as the plastic chrome moulding sits on.“ would I be able to put these onto my 1275gt if I was cutting the wings to make the clearance needed ?
I will be welding on a new bit once I’ve cut enough off because I know it keeps the wing rigid.
#2 mab01uk
mab01uk
  • 12,476 posts
Posted 16 April 2023 - 04:55 PM
WHEEL ARCH SET 2.25" WIDE PROFILE SUPERFIT
http://www.minispare...ng/MS133MS.aspx
I have fitted W&P style arches when cutting the front arch edges to gain clearance for both 6x10" and earlier for 6x13" wheels on full steering lock. I folded up a new flange after cutting away part of the wing (allowing the extra metal for the new folded up flange area). There is a certain amount of flex in the W&P front arches but go for the minimum needed or the arch main profile may distort too far and not sit flush to the wing. It is really a case of trial and error....
Minilite Mk 11 6x10 alloys with deeper dish ET-15 offset & W&P arches:-
https://www.theminif...mini/?p=2910309
Edited by mab01uk, 16 April 2023 - 04:58 PM.
