Hole In Footwell Patching
9 replies to this topic
#1 ac427
ac427
  • 679 posts
Posted 18 April 2023 - 08:44 PM
I've seen a few Mini's for sale with a metal plate in the footwells. Whether this is to cover a hole or provide a surface with questionable grip when wet is debatable.
What do you guys use apart from actually replacing the footwell floor properly?
#2 sonscar
sonscar
  • 3,047 posts
Posted 18 April 2023 - 09:13 PM
Carpet,Steve..
#3 DeadSquare
DeadSquare
  • 3,189 posts
Posted 18 April 2023 - 09:24 PM
Carpet,Steve..
3/8" plywood and mastic.
N.B.  I placed the plywood under the carpet
#4 ac427
ac427
  • 679 posts
Posted 18 April 2023 - 10:50 PM
Carpet,Steve..
Has it made it through an MOT and are you short of a deck chair?
#5 ac427
ac427
  • 679 posts
Posted 18 April 2023 - 10:51 PM
I would like to get my car through an MOT without a trip to B&Q.
I guess any old bit of aluminium sheet will do but is that good enough for the MOT?
#6 sonscar
sonscar
  • 3,047 posts
Posted 19 April 2023 - 06:51 AM
Welding is the only acceptable repair.Steve..
#7 mbolt998
mbolt998
  • 407 posts
Posted 19 April 2023 - 08:34 AM
No. But pretty much any old bit of steel sheet will do if you weld it in all the way around.
#8 Aly-g
Aly-g
  • 459 posts
  • Local Club: Still looking
Posted 19 April 2023 - 09:40 AM
I once brought a car that the dealer had repaired with newspaper and P38 , it had a year's MOT so this type of repair must be OK.! !.. ? NOT.
Allan
#9 stuart bowes
stuart bowes
  • 2,246 posts
Posted 19 April 2023 - 09:52 AM
as far as I understand it , so long as it passes the tap-with-a-little-hammer test then it's a pass
how you achieve that 'structural integrity' is then up for debate depending on your level of honesty / how temporary it is / whether you're dedicated to a proper repair in the reasonably near future
also underseal is often used to hide a multitude of sins which is obviously extremely poor practice to say the least but sometimes needs must I suppose
Answer #6 seems like the only right one from my perspective, in terms of access it's not exactly problematic there's far worse places to try and weld
Edited by stuart bowes, 19 April 2023 - 10:12 AM.
#10 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 19 April 2023 - 10:54 AM
Steel that's fully seam welded is the only acceptable way to repair
