Trying to work out why the dash warning for main beam is not working, all the rest of the lighting is fine, checked bulb and all good.
Where does the feed for this start from, is it the stalk?
Main Beam Dash Tell Tale.
Jammers777
, Apr 30 2023 06:05 PM
2 replies to this topic
Posted 30 April 2023 - 06:05 PM
Posted 30 April 2023 - 09:28 PM
Can't say for sure, but I would imagine the feed for the telltale starts at the steering column connector
Posted 01 May 2023 - 05:33 AM
It's a Blue / White wire and it's piggy-backed connected at the Loom side of the Plug for the Column.
If you look on that Plug, you'll see there's 2 Blue / White wires on the same terminal. One will be a thinner gauge wire than the other. It's that one.
