Hey,
I am still having issues with running in my newbuild. I am trying to tackle two problems -
1. The temp gauge goes to "hot" within 5-6 minutes of idling.
2. I cant get the car to "sit" when idling. Idle is all over the place and if down to 1,000rpm, will cut out.
I attach a couple of links to videos which will help explain things better than I can.
https://youtube.com/...w?feature=share
Video 1 the car has been run for about 5 minutes. Sequence has been - choke all the way out and it starts at about 2,000rpm. As the car begins to warm up, the revs climb up. They continue to climb unless I put the choke in a little. I put the choke in a little to bring the revs back down to 2,000 or lower and again they climb within a minute or so, back up. They do this until I have the choke fully in, when the choke is fully in its still idling (up and down) around 2,000rpm.
If I press the accelerator sharply and let it go again, throttle response is good but it "holds" the revs, for quite some time. If I rev it to 3,000rpm and bring my foot off the accelerator instantly, revs will stay at 3,000 for 5 seconds or so and slowly and inconsistently drop back down. Sometimes its longer.
At "idle", if I can call it that, revs move about, but constantly climb. sometimes they dip down quite a bit, then pick up but overall it slowly climbs.
Please ignore the temp gauge. I was attempting to by-pass the voltage stabiliser to determine if it was the issue re "overheating" - was it simply telling me it was overheating without it actually overheating, but despite testing that second gauge prior to installing, it decided part way through to give me a zero reading, initially working. Ive no idea why. Another thing to sort.
The second video is the carb off the car.
I have a spare carb. Its in worse condition than the one in the video but regards the piston, it moves MUCH more freely. The carb in the video is the one on the motor at present. Apologies for the crap quality of the videos, Im hoping the noise more than anything can assist with the first video.
Does the piston move satisfactorily or is it "sticky"? It moves consistently but it is much slower than the second carb I have, both with the dampers in.
Is there anything obvious in the videos thats causing the horrible revving? Timing has been done with a strobe to 12 degrees btdc at 2000rpm (approx obviously!)
Ive got a colortune kit coming to sort out the mixture and Ive got a compression kit coming as its something Ive never checked. Im really struggling to nail down what the issue is here.
