Door Hinge Threads
8 replies to this topic
#1 BenSwan
BenSwan
  • 43 posts
Posted 11 May 2023 - 12:50 PM
Hi all,
Any advice on removing these threads from the hinges? I've gave them a tap with a hammer and they seem solid.
Does anyone know where to get replacements from also?
Ben
#2 colinf1
colinf1
  • 1,059 posts
Posted 11 May 2023 - 01:57 PM
They are tapped and welded. You can grind them flat then drill out the old stud, then re-tap and weld in some 1/4" UNF threaded bar. Or M6 is closest metric if you cant get imperial
#3 BenSwan
BenSwan
  • 43 posts
Posted 11 May 2023 - 07:47 PM
Thanks @colinf1
Looking at the backs there's a larger circle which I assumed was a head of a bolt of come kind.
I'll give your instructions a go. Cheers
#4 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 11 May 2023 - 09:17 PM
Grind off the weld at the back, drill out the studs and then tap to M6 and fit metric lock nuts
#5 DeadSquare
DeadSquare
  • 3,375 posts
Posted 11 May 2023 - 09:27 PM
The weld penetrates about half the thickness of the hinge, so you can't "Grind it off".  It needs carefully drilling, centrally with at least a 3/8" drill bit.
The new stud is screwed half way into the hinge, welded and ground off flush
#6 Stu1961
Stu1961
  • 644 posts
  • Local Club: Still Looking
Posted 11 May 2023 - 10:17 PM
Hi Ben,
I had the same issue with the studs shearing off on removal of the doors.
First I cut off the remnants of the original studs then ground them flush with the surrounding hinge metal centre punched them and drilled them out, I re-tapped them 5/16" UNF and used all thread, which you could either weld in as per original or as I did use 5/16" nyloc nuts to secure the new studs. The only issue using nyloc nuts is some of them will foul the doors leading edge when it is opened to over come this I used half nyloc nuts on some of them , I also had to fettle the hinges a little to get the nuts to fully seat when tightened.
On re fitting the doors to the 'A posts' I also used nyloc nuts, between these and the 'A post' I placed a 6mm thick washer plate, the doors are very secure and I feel because of the washer plates the doors are definitely better supported.
Edited by Stu1961, 11 May 2023 - 10:19 PM.
#7 mbolt998
mbolt998
  • 433 posts
Posted 12 May 2023 - 07:42 AM
I'm now curious about how these were made at the factory. I don't think I've seen any (original) welds on the car that weren't just spot welds. Was there somebody making door hinges with oxy-acetylene back in the day?
#8 sonscar
sonscar
  • 3,197 posts
Posted 12 May 2023 - 07:50 AM
Electric resistance welding type of process?Steve..
#9 GraemeC
GraemeC
  • 7,467 posts
Posted 12 May 2023 - 09:25 AM
They wouldn't have been made in the assembly factory - they'd be a bought in part from a third party supplier.
