Stripped Sump Plug Adapter Time
12 replies to this topic
#1 Gaz66
Gaz66
  • 963 posts
Posted 13 May 2023 - 08:32 PM
Ive just stripped a gearbox for my project and noticed the sump plug has stripped at some point and been helicoiled.
The helicoil is hanging inside the gearbox by around 15mm so its either wound itself in as the plug was screwed in or never was cut to length in the first place.
Anyway. ....cut to the chase.
Im going to go down the 20mm tapped bolt route with the standard sump plug screwed into that etc etc.
Would a coarse thread bolt be better than a fine thread for loctiting in?
Edited by Gaz66, 13 May 2023 - 08:33 PM.
#2 Quinlan minor
Quinlan minor
  • 1,208 posts
  • Local Club: LSMOC
Posted 13 May 2023 - 08:53 PM
A Time-Sert would be my recommendation.
#3 Gaz66
Gaz66
  • 963 posts
Posted 13 May 2023 - 10:23 PM
Thats ok if you have the tooling to do it otherwise its a bit expensive.
If I could find someone who had the tooling it may be an option.
#4 Tds76
Tds76
  • 87 posts
Posted 14 May 2023 - 12:13 AM
A fine thread is more suitable than coarse - stronger and more contact surface for the same nominal size.
#5 Gaz66
Gaz66
  • 963 posts
Posted 14 May 2023 - 12:16 AM
A quick look on the net shows helicoiling only at the machine shops near me (Leeds) so the time sert option is looking grim at the moment.
#6 Steam
Steam
  • 824 posts
  • Local Club: Victorian Mini Club
Posted 14 May 2023 - 01:11 AM
Helicoil works well for this fix. Did one 3 years ago and still fine after numerous oil changes.
#7 GraemeC
GraemeC
  • 7,440 posts
Posted 14 May 2023 - 08:03 AM
At that size I feel a standard M20 will be course enough
#8 Spider
  • 15,162 posts
Posted 14 May 2023 - 08:46 AM
I've done many now, I just use a standard M20 x 2.5 for this.
#9 Shooter63
Shooter63
  • 1,084 posts
Posted 14 May 2023 - 10:42 AM
Tadaaa
Shooter
#10 Gaz66
Gaz66
  • 963 posts
Posted 14 May 2023 - 11:08 AM
Tadaaa
Shooter
That looks cheeky 👍
What size sump plug did you use?
Edited by Gaz66, 14 May 2023 - 02:33 PM.
#11 Shooter63
Shooter63
  • 1,084 posts
Posted 14 May 2023 - 05:30 PM
Tadaaa
Shooter
That looks cheeky
First off it's not my idea, I nicked it off spider, all I changed was the sump plug size to 14mm and to be honest I used that size because I already had a tap in my tap and die draw. Total cost was about £3.00 for the material £4.00 for the sump plug and £18,0000.00 for the electricity to power my lathe for 1/2hr
Shooter
#12 Gaz66
Gaz66
  • 963 posts
Posted 14 May 2023 - 07:28 PM
Sump plug update.
I just took out the sump plug and the helicoil is fully fitted and not wound out into the inside of the gearbox.
Now then, do I just chop it off inside the box and leave it or take it out and do the adapter. Decisions decisions.
Are helicoils difficult to remove?
#13 Steam
Steam
  • 824 posts
Posted 15 May 2023 - 02:26 AM
If it works and doesn't leak I would leave it. If it aint broke don't fix it.
The only way to get helicoils out is to wreck them winding and pulling like a spring.
