Metro Brake Caliper To Mini Hub - Torque Setting
Best Answer Lplus , 23 May 2023 - 08:10 AM
Hello,
Just wondering if anyone knows what the correct torque setting is for the 2 bolts which hold the calipers to the hub.
Metro 4 pot (originals). They are 3/8" UNF but somewhat special
Using these bolts: https://www.minispar...nt/ERA1128.aspx
Given they are somewhat special, unsure if there is a specific torque which should be used.
I have had my calipers off after being on about 10 years, and thought I would check before putting them back on.
35 - 40 lb.ft sound right?
standard torque for 3/8 unf caliper bolts is 38 lb/ft from the book. Since that's the thread and the only difference in the bolt is the diameter of the plain section, I'd go with that torque.
Go to the full post
1 reply to this topic
#1 WanaGo
WanaGo
  • 98 posts
Posted 22 May 2023 - 10:25 PM
Hello,
Edited by WanaGo, 22 May 2023 - 10:27 PM.
#2 Lplus
Lplus
  • 911 posts
Posted 23 May 2023 - 08:10 AM   Best Answer
Hello,
