Hi folks,
My mini is on a gently sloped car porch and I need to do some tappet adjustments.
I cannot access the crankshaft pulley or the alternator pulley easily. The mini is a daily so its not seized up or anything
I tried to turn the engine (plugs out, neutral gear) by turning the fan blade, doesn't work and I didn't want to risk damage.
I also tried to jack up front left wheel (plugs in, 4th gear) but again I could not turn the wheel or at least it was very stiff.
What am I doing wrong? Should I jack up the one wheel, remove the plugs and try to rotate the wheel while in another gear? 3rd or 4th?
And for those who did it via the wheel rotation method, are you supposed to use a substantial amount of strength or is it fairly easily to rotate with the plugs out?
Thanks!
Kopi
