Spares Kit
9 replies to this topic
#1 OllieWally
OllieWally
    Starting My Mini Up
  • 1 posts
Posted 24 May 2023 - 04:28 PM
Hey, I think this is the correct section to ask this as it's not really a technical question or if anyone else has had a similar feed please let me know. After braking down just outside Brighton on the L2B run this weekend it turns out the culprit was the rotor arm which I couldn't test until I got home. The RAC guy who picked me up and spent way longer than he should trying to get me going suggested I carry a basic spares kit with items like rotor arm, HT leads and distributor cap as a simple fix can get you on your way.
Im looking to get a few parts to carry with me and wondering if anyone has any suggestions on what would be sensible to get, eg spark plugs, bulbs etc...
#2 Designer
Designer
  • 616 posts
  • Local Club: LSMOC
Posted 24 May 2023 - 06:57 PM
Hi welcome to the forum and the we broke down club.
We broke down at the bottom of the ramp down to Madeira Drive. Got pushed to a great parking spot otherwise would have been up at the Marina.
Fortunately one of the Marshals discovered the reason for the engine failure was the connector on the low voltage wire from the distributor to the coil was faulty or dirty so no spark. Luckily a quick fix, made it back home in Surrey no problem.
My fault I had cleaned and checked all the other connectors in the engine bay but forgot that one.
Suggest a spare set of plugs and a spare set of points. We always carry five litres of water just in case of over heating problems.
#3 stuart bowes
stuart bowes
  • 2,246 posts
Posted 24 May 2023 - 07:26 PM
possibly stating the obvious but I have always carried jump leads in my car just in case.  you can always find someone to jump from but leads themselves are less common
plus I've used them to help out other people numerous times
#4 Spider
  • 15,143 posts
Posted 25 May 2023 - 07:17 AM
I travel often-ish and in to remote areas, here's a basic list of what we carry in our group (though, this varies depending on where we are going);-
Fan Belt
Top Hose
Bottom hose
½” Heater hose
Spark Plugs
Distributor - complete
HT Leads
Coil
Engine mount
Radiator Pressure Cap
Radiator Blanking Cap
Trailing Arm Pins
Bearings  for Trailing Arm Pin
Front Wheel Bearings set
CV
Pot Joint
Radiator Cowling Screws
Rear Trumpet
Rear Wheel Bearing Set
Exhaust Mount – Rectangular Type
Cotton Reel Mounts
Puncture Repair Kit
Tyre Plugs
Rubber for sidewall repair
Inner Tubes
Steering Rack Boots
Throttle Cables
Water Pumps
Front Shocks
Rear Shocks
LH Drive Shaft
RH Drive Shaft
Clutch Thrust Bearing
Hose Clamps suit Radiator
Hose Clamps suit Fuel system
Hose Clamps suit heater hose
Engine Steady Rubbers
Araldite
Fibreglass Matting
Fuel Pump - Electric
Throttle Return Spring
Hilos
Front Wheel Studs
Rear Wheel Studs
Wheel Nuts
CV Nut
CV Tapered Collar
Steering Rack Rod Ends
Alternator (15ACR)
Thermostat - 82 deg
Clutch Slave Cyl
Comp Front Bump Stops
Wire (electrical)
Wire (steel / iron)
Split Pins
Nuts / Bolts / Washers
Fuel Cap
Steering Lock Key
CV Boot - Inner
CV Boot - Outer
Roll Pins
Fuel Filter
Ball Joints
Knuckle Joint
Rebound Stops
Lower Inner Arm Rubbers
Caster Bar Rubbers
Master Cylinder Clevis Pins
Rear Brake Hose
Clutch Hose
Bonnet Rubbers
Fuel Hose
Brake Pads
U Bolts
Silastic
Bleed Nipples
Microphone - CB
#5 Designer
Designer
  • 616 posts
  • Local Club: LSMOC
Posted 25 May 2023 - 07:32 AM
Fan Belt
Top Hose
Bottom hose
½” Heater hose
Spark Plugs
HT Leads
Coil
Engine mount
Trailing Arm Pins
CV
Pot Joint
Rear Trumpet
Cotton Reel Mounts
Puncture Repair Kit
Tyre Plugs
Inner Tubes
Steering Rack Boots
Throttle Cables
Water Pumps
Front Shocks
Rear Shocks
LH Drive Shaft
RH Drive Shaft
Araldite
Fibreglass Matting
Hilos
Front Wheel Studs
Rear Wheel Studs
Wheel Nuts
CV Nut
CV Tapered Collar
Alternator (15ACR)
Thermostat - 82 deg
Clutch Slave Cyl
Wire (electrical)
Wire (steel / iron)
Split Pins
Fuel Cap
Steering Lock Key
CV Boot - Inner
CV Boot - Outer
Roll Pins
Fuel Filter
Ball Joints
Knuckle Joint
Rebound Stops
Caster Bar Rubbers
Rear Brake Hose
Clutch Hose
Bonnet Rubbers
Fuel Hose
Brake Pads
U Bolts
Silastic
Bleed Nipples
Microphone - CB
In other words a complete Moke on a trailer :lol:  :lol:  :lol:
Sorry couldn't resist it.
I am not surprised at that list considering the amazing trips you and your friends take. I don't think I would consider making them in a modern all swinging all dancing all terrain vehicle.
Edited by Designer, 26 May 2023 - 05:28 AM.
#6 Steam
Steam
  • 822 posts
  • Local Club: Victorian Mini Club
Posted 25 May 2023 - 09:29 AM
Notwithstanding Spiders shedload, which is understandable if going bush a more realistic kit would be spare wheel jack and wheel brace and pliers and screwdriver, for shorter trips.
For longer trips I add full tool kit and multimeter, plugs leads and distributor, fuses and a selection of connectors. Hoses and 3l of water.
There is not much else that will stop you getting to a place to fix. Anything bigger will probably not be fixable on the side of the road anyway.
#7 DeadSquare
DeadSquare
  • 3,189 posts
Posted 25 May 2023 - 01:33 PM
A well proportioned Girl Friend, in Hot Pants a skimpy Tank Top.
#8 stuart bowes
stuart bowes
  • 2,246 posts
Posted 25 May 2023 - 11:36 PM
a bar and socket for undoing wheel nuts.  as in a proper bar not some flimsy little thing like you get in the kit with newer cars these days, one attempt on a wheel nut and it bends.  I have a 2 foot bar in the boot and it just makes things very easy and quick
obviously be sensible when doing the nuts back up though enough is enough
Edited by stuart bowes, 25 May 2023 - 11:40 PM.
#9 Steam
Steam
  • 822 posts
Posted 26 May 2023 - 12:52 AM
Largest bar to undo, smallest bar to tighten. ;-)
#10 68+86auto
68+86auto
  • 1,011 posts
  • Local Club: Queensland Mini Car Club
Posted 26 May 2023 - 04:56 AM
As much as I don't want to resort to being towed there is a limit of what can be carried. I only recently got my mini back on the road so what I am currently carrying is a bit different. Make sure any parts you take can be fitted with the tools you carry otherwise it is close to pointless.
This is not what I currently carry but what I intend on carrying for my drives to work. Currently I take heaps of tools which I could probably tear almost the entire mini down with. I intend on eventually reducing the tool count too. These items are based on what I think could fail and what I have experienced failing.
Points
feeler gauge for points
Condenser
Distributor cap
Rotor
5l oil
5l water/coolant
Thermostat housing gaskets
Gasket Sealant for thermostat housing
some type of wire to tie stuff up (mechanics/aviation wire)
Tape
wheel brace
jack
spare wheel
spark plug socket
spark plug brush
some kind of work light (need to save phone battery, I have had mine go flat waiting to be towed)
fuel pump
electrical wire/test leads
That is what I can think of right now.
For the trips which are multiple 100s of km I will take a list closer to what Spider says.
The items I have been towed for were:
Ignition issues - Worn out or Chinese distributors.
Ignition issues - water in distributor, just needed to be dried out but here they tow for free off toll roads for safety
Auto selector oil seal popped out - I didn't work out what the problem was, if I did I could have popped it back in and refilled with oil to get me home
Fuel pump - Rebuilt mechanical fuel pump decided to fail
head gasket/overheat - was towed (again for free) to the nearby mini business where I refilled with water and drove it home with the cap loose.
Edited by 68+86auto, 26 May 2023 - 04:59 AM.
