I have run the breathers open on the car for a number of years but I am considering re connecting back to the carbs.
May seem like a silly question but I can't remember how it was originally set up with the pipes running to the carbs.
I have twin SU's and the pipe for the breather on the carb is currently blanked off with a valve cap. Could I simply run the timing chain into one SU and then the crankcase into another?
Or is there another way I should do it?
The cannister ont he crankcase is pretty mucky inside so will be getting cleaned out before refitting.
Many thanks
