Anyone done this yet ?
Not realy a problem as mine just lifts off, but i would like a hinge at the front.
there are two lugs on the front subframe where the origional body bolts on and i can use them for some sort of hinge mounting points. But the problem is when you lift the front the lower valance will hit the two vertical tubes on the subframe. Do i need some special sort of hinge that comes forward when opening or is there an easy way round Thanks ian
FLIP FRONT on zcars tube subframe
koss
, Nov 15 2006 12:54 PM
No replies to this topic
