Reverse Rims
9 replies to this topic
#1 OscarMini
OscarMini
  • 12 posts
Posted 29 May 2023 - 07:34 AM
Maybe this has been discussed before, but I have not been able to find a definite answer:
Will "reverse" 4.5x10 rims fit on my mini 850 from 1978? It is completly standard with original drum brake setup all around.
I have small arches (original arches, - these became mandatory in 1978 in Denmark I believe) and I want to fill out the fenders/arches it just does not look right with original 3.5" wheels.
Other option is to go with the Cooper 4.5 not reversed. What are the thoughts on reversed 4.5 ET 16 vs Cooper 4.5 ET 35 for my application ?
Thank you!
#2 DeadSquare
DeadSquare
  • 3,205 posts
Posted 29 May 2023 - 07:57 AM
4.5" Cooper S wheels won't fit on the rear without a spacer, but will fit OK on the front.
#3 Shooter63
Shooter63
  • 1,102 posts
Posted 29 May 2023 - 08:19 AM
The reverse rims were made for drum brake cars so should fit fine.
Shooter
#4 OscarMini
OscarMini
  • 12 posts
Posted 29 May 2023 - 09:00 AM
thanks guys. Also I have some good 145/80 tires I want to use. are these fine for the 4.5 wide rim?
#5 DeadSquare
DeadSquare
  • 3,205 posts
Posted 29 May 2023 - 11:05 AM
Yes, until the tread wears off.
#6 OscarMini
OscarMini
  • 12 posts
Posted 29 May 2023 - 12:50 PM
Woops, I just saw it was 165/70 tires I have. Will these be too big for the 4.5 rims?
#7 DeadSquare
DeadSquare
  • 3,205 posts
Posted 29 May 2023 - 01:22 PM
They will be OK on the front, but keep the tyre pressure up, too low is not good.
On the rear, they should fit, but get very close to the radius arms, and if a small stone gets flicked up, it can lodge between the radius arm and the side-wall of the tyre and if it cuts through the side-wall, the tyre deflates instantly.
#8 Homersimpson
Homersimpson
  • 840 posts
Posted 29 May 2023 - 09:23 PM
If the wheels are actually S reverse rims rather than S rims then they will fit a drum braked car fine and 165/70/10 tyres would be correct for them.  Thats what I used to run on quite a few of my minis.
The difference is that S rims were supplied with the original Mini Cooper S and are designed for a car with front discs and rear drums with integral spacers which push the wheel hubs out further where as the S reverse rims were (as far as I understand) an aftermarket wheel that looked like a Cooper S wheel but had more offset so that they would fit onto drum braked minis without rubbing.
If you put S reverse rims on a car with front discs and rear spaced drums they stick out a bit further than the original Cooper S wheels.
#9 timmy850
timmy850
  • 3,409 posts
  • Local Club: MITG
Posted 30 May 2023 - 04:31 AM
First up - 145 or 165 tyres will be fine on 4.5” wide rims
Reverse wheels:
4.5” wide and offset 16
Fit perfect with flat drums front and back and no wheel arches
If you have stepped/spacer drums then you’ll need small wheel arches
Cooper S wheels
4.5” wide and offset 35 (these will be sunken in the arches 19mm per side compared to the reverse wheels)
Fit perfect with stepped/spacer drums front and back (or 7.5” discs front and spacer drums at the back)
Won’t fit with standard flat drums
Flat drums
http://www.minispare...ums/GDB105.aspx
Spacer drums
http://www.minispare...ums/GDB106.aspx
#10 panky
panky
  • 1,793 posts
Posted 30 May 2023 - 01:22 PM
You will also need to fit longer studs with the spacer drums
