Metro Turbo Gearbox Casing Identification?
3 replies to this topic
#1 ac427
ac427
  • 679 posts
Posted 30 May 2023 - 08:04 PM
I think the only difference between the an A+ DAM5626 gearbox and the Metro Turbo gearbox (apart from the ratios) is a larger idler bearing.
Can a Metro Turbo gearbox be identified from an A+ gearbox by external casing markings?
#2 nicklouse
  • 18,689 posts
Posted 30 May 2023 - 08:07 PM
The larger idler bearing is common on the later boxes.
the turbo transfer case used a larger input gear bearing.
#3 ac427
ac427
  • 679 posts
Posted 31 May 2023 - 06:49 PM
Thanks Nick, So it is really only the transfer case that is different then?
#4 Ethel
  • 26,060 posts
Posted 31 May 2023 - 10:05 PM
3.2 final drive. Possibly identifiable by speedo drive gear???
As Nick says the nose bearing on the 1st motion shaft is bigger, 43 vs 35 mm OD
