This is a 1275 A+, and I have no knowledge of its past though when torn-down it was pretty fair internally.
I've had the block newly skimmed (to raise CR, not because of any fault), and a few new valve-guides in the head. By a reputable experienced engineer.
Rebuilt out-of-the-car with a new TAM1521 (Bk450) gasket from MiniSpares. Torqued-up per the book. Dropped into the car, where it has sat for 3 months. This engine has not been started since it was assembled.
Added coolant today. And I have a water leak right off the bat from the gasket - just under the heater take-off. (No, it's not the heater take-off that's leaking, sadly.) And this is without any pressure in the system! A couple of drops per hour.
I've tried the loosen-half-a-turn-in-order-and-retorque on the bolts (normally you'd do it after a few miles, but hey, it's worth a stab). No change.
Break it to me gently...
[attachment=218816:Gasket.jpg]
Edited by alpder, 08 June 2023 - 10:48 AM.
