Gauge Calibration And Repair
Posted 08 June 2023 - 03:03 PM
Posted 08 June 2023 - 03:46 PM
Posted 08 June 2023 - 04:14 PM
I second speedycables. I posted mine all the way from Malaysia to have it calibrated. They did an absolutely fantastic job, and the speedo came back like brand new!
When you want your speedo calibrated they have some measurements they need you to take as it has to be correctly set against your gearbox and your wheel size.
Posted 08 June 2023 - 04:39 PM
But given the customer has to take various measurements and they use them as the basis of their calibration it's quite likely that the previous owner who had it done wasn't very good with a tape measure ☺️
Edited by Vanman20, 08 June 2023 - 04:39 PM.
Posted 08 June 2023 - 09:53 PM
Posted 09 June 2023 - 12:44 AM
It is reasonably easy to check if the speedo is operating at the correct speed. You need the inner of a speedo cable and a way to turn it at a known speed.
There is a number on the face of the speedo which is how many turns per mile/km. If you turn the cable at that speed it should be at 60. you can calculate what it should read at other input speeds.
