I'm tempted to purchase one of the new mini-spares injection flywheels and attempt to find someone competent to balance it.
Thanks in advanced.
Posted 10 June 2023 - 09:10 AM
Thanks in advanced.
Posted 10 June 2023 - 01:13 PM
With what did you suspect that your clutch plate had been contaminated ?
If it was contaminated, that must be cured.
check for oil on the clutch plate by rubbing it with brown paper.
If it was oil, check and to be sure, replace the red oils seal and either burn the oil out of the clutch plate with a propane torch or buy a new plate.
If you are going to buy a new fly wheel and have it balanced, take the crank, conrods and pistons along as well, to make a pucka job.
Posted 10 June 2023 - 01:33 PM
Edited by tag338, 10 June 2023 - 01:34 PM.
Posted 10 June 2023 - 02:55 PM
If you have done the oil seal, put it all back together with the new clutch plate, and enjoy this summer's motoring
Posted 10 June 2023 - 03:20 PM
There is no point in trying to balance the flywheel on its own. It must be balanced as a sub-assembly of crankshaft, flywheel and front pulley/damper.
There really is not much wrong with your flywheel. As already said, just re-asemble it with a correctly fitted 'red' seal (use the proper fitting tool) and a new clutch plate. Check the condition of the release bearing and the clutch arm clevis pins together with the ball end of the clutch arm and slave cylinder.
Posted 10 June 2023 - 03:29 PM
It doesn't have to be balanced as a subassembly. If the crank is being balanced then balancing the flywheel and pulley is a worthwhile pursuit, but when changing the pressure plate and friction plate on a verto clutch the flywheel/pressure plate should be balanced before fitting irrespective of the balance of the crankshaft.
Posted 10 June 2023 - 05:35 PM
Edited by tag338, 10 June 2023 - 05:39 PM.
Posted 10 June 2023 - 05:45 PM
Edited by ACDodd, 10 June 2023 - 05:48 PM.
