So!, a combination of a misfire and a less than sympathetic driver who slipped the clutch has resulted in difficulty to select gears (especially reverse) the pedal was only doing any work when it was virtually embedded in the bulkhead.
Knowing this, I have stripped everything out in order to replace the clutch plate; only to find that it looks to be ok and is measuring around 7.3mm thick. its a 180mm dia plate and the engine is a total bitsa modded 1275 in a 1990 RSP.
So!; what's the consensus? have I gone in the wrong direction here? from what I can ascertain; there looks to be more than enough meat left on it.
additional info - I did try adjusting the throw by adjusting the locknut by a flat before I went full scope.
any advice gratefully received.
