Lambda Probe Mini 1.3I 1992 Mpi
3 replies to this topic
#1 Mr.Horno
Mr.Horno
    Starting My Mini Up
  • 1 posts
Posted 17 June 2023 - 09:25 AM
Hi folks!
I hope you're all doing well. I'm currently facing a problem with my beloved 1992 Mini Rover 1.3 SPI during the vehicle inspection regarding emissions, and I'm in need of some assistance and advice.
The issue revolves around the lambda values, which consistently remain at 1070mV according to the readings from the Rover MEMS application. However, what's even more peculiar is that when I turn off the engine, I observe the values rapidly dropping to around 200mV and then gradually increasing back up to 1070mV. It's almost like a capacitor charging.
Up to this point, I have taken several steps to address the problem. I have sealed all exhaust leaks, replaced the catalytic converter, and purchased a new Bosch lambda sensor. Despite these efforts, I'm still unable to pass the emissions test.
I'm reaching out to this knowledgeable community for any additional suggestions or troubleshooting steps I could take to resolve this persistent issue. Have any of you encountered a similar situation with your Mini Rover or have insights into what might be causing this strange behavior in the lambda values?
Your help would be greatly appreciated. I'm eager to find a solution and successfully pass the emissions test.
(I have some graphs from the application that would be quite helpful in understanding the situation I'm describing. Unfortunately, due to forum regulations, I'm unable to upload photos.)
Thank you all in advance for your support and suggestions
#2 MatthewsDad
MatthewsDad
  • 817 posts
Posted 17 June 2023 - 06:54 PM
I recently had similar high lambda readings (greater than 1,000mV) which stayed high and didn't fluctuate. Faulty lambda identifed though testing. Replaced with a Bosch lambda and everything back to normal, possibly better than before.
#3 MatthewsDad
MatthewsDad
  • 817 posts
Posted 17 June 2023 - 06:56 PM
Sorry should add my mini is a standard 95spi
#4 madazv8
madazv8
  • 139 posts
Posted 18 June 2023 - 05:21 AM
If the vacuum lines are all OK, then have a look at the coolant temp sensor.  https://www.theminif...ady-high-840mv/
