Spi Convertible Indicator Relay Clicking Constantly After Wash.
1 reply to this topic
#1 Dalla
Dalla
  • 14 posts
Posted 17 June 2023 - 11:35 AM
Hi Guys
Washed my car this morning. After washing it, I noticed that the indicator relay is clicking rather fast. It does it no matter if the engine is switched on or off and regardless if ignition is on.
- The indicators still work, front and back.
- The hazards still work, front and back.
When switching on the indicators the frequency of the relay settles on normal. Switching off the indicators it is back on a high frequency. Any ideas what can be causing this?
Edited by Dalla, 17 June 2023 - 11:53 AM.
#2 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 20 June 2023 - 07:47 AM
Do the indicators also flash, or is it just the relay ticking?
If the latter, how are you sure its the indicator relay?
And the obvious answer to your questio : moisture will have likely gotten somewhere it shouldn't and is shorting a contact.
